So, V&H hat geantwortet :-) Angefragt:
Penzl without Baffles, K&N Filter in Stock Air Box
Use the map for V&H Twin Slash Round slip ons, standard baffle for this application.
Run the map for 1-2 tanks of fuel, then use Autotune after that if needed. After flashing the base map, I would recommend immediately adjusting the throttle progressivity to 'Aggressive' for much improved throttle response and overall feel.
Throttle progressivity and Autotune instructions below.
THROTTLE PROGRESSIVITY(do this after flashing map) 1) Turn key/handlebar switch both on and connect to FP3 app2) Go to ‘Map Optimizations’3) Go to ‘Throttle Progressivity’4) Turn the dial to ‘Aggressive’5) Press lightning bolt to flash changes to bike.
AUTOTUNE INSTRUCTIONS (only use if needed after 1-2 tanks of fuel with Base Map)**
Be advised that while Autotune is active the bike will not perform optimally. The AFR table is not optimized, and the cranking fuel/accel enrichment are turned off. This may translate into poor cold start performance, erratic idle, poor throttle response, and general ride quality issues. These will resolve once you ‘Finish’ the Autotune.
Letting the bike fully warmup before riding while Autotune is active will help to slightly diminish some of these symptoms.
1) Go to the Autotune tab in the main menu of the app.
2) a base map from which to start ( whichever slot your correct map is in, most likely slot 1 if this is a brand new FP3.
3) ‘Quick Setup'
4) It will have you flash the bike to run Autotune, follow the in app instructions (i.e. bike off for 30 seconds, etc.)
5) Once Autotune is active, you'll want to break it down into 3 sessions, approx. 20-30 minutes each.
6) After your first 20-30 minute session, open the app and go into the Autotune section. 'Apply Learned Values' and 'Apply'. This will take the data learned and store it, allowing for more data to be collected.
7) After the second 20-30 minute session do the same thing - ‘Apply Learned Values’ and then ‘Apply'.
After the 3rd total session, 'Apply Learned Values’ and then '
Finish'. This will complete the Autotune, taking everything learned from each 'Apply' and will build the map/put it into a new slot.
Dieser Beitrag wurde schon 1 mal editiert, zum letzten mal von Big A am 07.03.2021 10:24.
