Kleine Reifenhilfe erforderlich Twincam-Forum
aus Dresden
fährt: FLHRCI 05
FLHRCI ist offline FLHRCI
2992 Posts seit 24.01.2008
aus Dresden
fährt: FLHRCI 05
Homepage von FLHRCI
Neuer Beitrag 05.10.2010 15:43
a.a.O. steht folgendes:
FRONT WHEEL 2.4
REMOVAL
1. Place the motorcycle on a hydraulic center stand with the
front wheel raised off the ground.
2. Inspect wheel bearings. See
2.11 SEALED WHEEL
BEARINGS
3. If present, carefully cut three cable straps to release front
wheel speed sensor cable and front fender tip lamp wires
from left caliper brake hose.
4. See
Figure 2-2. Remove two brake caliper mounting
fasteners (1). Slide brake caliper straight down to remove
from brake disc. Secure caliper to rail of engine guard
using cable strap.
5. If necessary, remove clip (2) to release wheel speed
sensor harness from bracket.
6. Remove brake caliper on right side of wheel.
NOTE
Do not operate the front brake hand lever with the front wheel
removed or the caliper pistons may be forced out. Reseating
pistons requires disassembly of the brake caliper.
7. See
Figure 2-3. Insert screwdriver or steel rod through
hole in axle (11) on right side of motorcycle. While holding
axle stationary, remove the axle nut (1) and flat washer
(2).
8. Loosen the two axle holder nuts at bottom of right side
fork slider.
sm05733
1. Caliper fasteners
2. Wheel speed sensor cable retainer
Figure 2-2. Remove Front Caliper
9. Using a soft mallet, gently tap end of axle towards right
side of motorcycle. Catching external spacer(s), pull axle
free from fork sliders, front wheel speed sensor (if ABS
equipped), and wheel hub.
NOTE
If ABS equipped, never pull wheel speed sensor cable taut or
use to retain wheel, axle or other components. Always keep
wheel speed sensor (and ABS encoder bearing) away from
magnetic fields (such as magnetic parts trays, magnetic base
dial indicators, alternator rotors, etc.) or damage will occur.
10. If necessary, remove five screws (13) to release brake
discs from hub.
HOME
2009
Gruss Hans
I-mehl
twincam-forum
harley-café-dresden
Gruss Hans
I-mehl
twincam-forum
fährt: FLHT
3286 Posts seit 15.06.2008
fährt: FLHT
Neuer Beitrag 05.10.2010 21:30
2. Gabelholme düfen beim Radeinbau aus sehr verständlichen Gründen (siehe etwa Uli) nicht gegeneinander gedrückt werden (entgegen dem HD-Touring Handbuch 2009, Kap. 2.4 unter Einbau Punkt 9).
@Klaus
was steht denn da genau, bitte????????????
ich vermute mal da, steht auch was mit einem Bohrer oder eisenstängelein????
hier gibet es für kleines geld ne englische anleitung für
softail 2007
allerdings nur in englisch
BLUETHUNDER
Mehlfach
BLUETHUNDER
Dieser Beitrag wurde schon 1 mal editiert, zum letzten mal von BLUETHUNDER am 05.10.2010 21:40.
aus Dresden
fährt: FLHRCI 05
aus Dresden
fährt: FLHRCI 05
Homepage von FLHRCI
Neuer Beitrag 06.10.2010 06:15
@Kurti:
was da steht hab ich doch geschrieben - auch wenn‘s kleingedruckt ist 😁
Ich les da nix von Druck auf die Gabelholme, genauer gesagt gar nix vom Wiedereinbau, nur vom Ausbau.
Gruss Hans
I-mehl
twincam-forum
harley-café-dresden
Gruss Hans
I-mehl
twincam-forum
Golf333blau · seit
Golf333blau
Neuer Beitrag 06.10.2010 08:38
@silent
zur der Reifensache nur folgendes:
Unter Reifenreparatur auf der Metzeler-Seite steht die fragliche Stelle mit § 36, die mich verwirrt hat.
Soll dies etwas bedeuten, dass Neureifen der Version TL mit Schläuchen ausgestattet werden dürfen und nur die Reparatur von TL-Reifen mit Schläuchen verboten ist?
Nachvollziehbar ist dies nicht.
@ BLUETHUNDER
hier ist die Stelle aus dem Handbuch (Sorry dies ist eine schlechte Kopie von einer PDF-Datei):
Erned unneS chichtL OCTITEA NTI-SEIZEG leitmittealu f
die Achse, Lagerbohrungen und die Bohrung der
Distanzhülsaeu ftr agen.
a Die Achse durch das rechte Gleitrohr und das externe
Distanzstücikn die Radnabes chieben.
HINWEIS
furcrstellen. dass die Rillen an den externen Distanzstücken
otur der Passstifta m Vorderraddrehzahlsenso(rf alls mit ABS
o4erüstet) an der Außenseite liegen. Wenn das Motonad
-tt mit ABS ausgerüsfef lsf, können die externen Distanzab<
e zwischen der linken und rechten Radnabenseite ausge-
-.eht werden.
i Die Achsed urch den Vorderrad-Drehzahlsens(ofra llsm it
ABS ausgerüstet)b zw.d urchd as zweiteä ußereD istanzstücku
nd das linkeG abelgleitrohsrc hieben.
3 FlacheU nterlegscheibuen d Achsmuttear nbringen.
,- Srehe Abbildung 2-4. Wenn das Motorrad mit ABS ausgenrsteti
st,d enV orderraddrehzahlsensnoarc hl inksd rehen,
bis der PassstiftK ontaktm it dem Absatza m linkenG leitrohr
hat.
DreA chsef ixierenu nd die Achsmuttear uf ein Drehmoment
von 81,4-88,1 N.m (60-65 ft-lb) anziehen.
Das rechte Gabelgleitrohrn ach innen schieben,b is es
das externe Distanzstück berührt und die Muttern des
Achshaltersa uf ein Drehmomentv on 14,9-20,3 N‘m
(1 32-180in - lb)a nziehen.
HINWEIS
Abbildung2 -3. Das Raddrehzahlsensorkabels, ofern es
wurde, wieder an der Halterung (cool befestigen.
achten, dass die Zunge (mit Bezeichnung ABS) aut
Clip von der Innenseite in den Schlitz der Halterung ein‘
wird. Der Clip kann nicht mehr eingebaut werden,
di e Befestgi un g stei I e ang ese tzt wu r de n .
Ex‘rbaud es linkenB remssattelSs iehe2 .15 VORDERRADBREMSSATTEL.
MfG
Klaus
fährt: FLHT
fährt: FLHT
Neuer Beitrag 06.10.2010 09:27
Die Achse fixieren und die Achsmutter  auf ein Drehmoment
von81,4-88,1 N.m (60-65 ft-lb) anziehen.
Das rechteGabelgleitrohrn ach innen schieben,b is es
das externeDistanzstück berührt und die Muttern des
Achshalters auf ein Drehmoment von 14,9-20,3 N‘m
(1 32-180in- lb)anziehen.
@Klaus
sorry, aber das macht mich stutzig,
kann in meinen augen nur ne falsche übersetzung sein.
hat hier vielleicht jemand die englische einbauanleitung für das vorderrad von der touring 2009
und kann das mal posten.
der Entenvogel vielleicht eine haben tut?
oder auch jeder andre,
Danke
BLUETHUNDER
Mehlfach
BLUETHUNDER
silent grey ist offline silent grey · 3974 seit 1506419882
Neuer Beitrag 06.10.2010 09:46
..."Soll dies etwas bedeuten, dass Neureifen der Version TL mit Schläuchen ausgestattet werden dürfen und nur die Reparatur von TL-Reifen mit Schläuchen verboten ist?"...
nein, das bedeutet lediglich, dass es erlaubt ist, Schlauchlosreifen dort mit einem Schlauch zu montieren, wo es nicht anders machbar ist. Dieses kann aus konstruktiven Gründen (HD Drahtspeichenräder) oder mangels Verfügbarkeit (Reifenart) der Fall werden. Dass damit nicht Tür und Tor für krude Reparatureingriffe geöffnet werden soll, versteht sich von selbst.
Danke für den Text, auf den Bezug genommen wurde, auch wenn er etwas skurril rüberkommt. Selbst wenn die Fertigungsqualität mittlerweile zugenommen haben mag, lassen die in einer Serienfertigung unvermeidbaren Fertigungtoleranzen, die sich je nach Lage sehr unterschiedlich ausprägen können, eine derart fixe Positionierung nicht zu, wenn eine solch sensible Baugruppe, wie es eine Teleskopgabel nun mal ist, einwandfrei funktionieren soll.
Wer als Selbstschrauber bei solchen Sachen unsicher ist oder sich mit den grundlegenden Anwendungen gar nicht auskennt, sollte entsprechende Arbeiten grundsätzlich von einem Fachbetrieb vornehmen lassen.
Durchaus möglich, dass die entsprechende Passage im amerikanischen Original keine Zweifel über eine absolut korrekte Verfahrensweise aufkommen lässt; Übersetzer von derartigen Werken sind nicht immer Fachleute, die die abgehandelten Themen bis ins Detail beherrschen. Darüber hinaus, wie schon einmal herausgestellt: wo Menschen arbeiten, werden auch Fehler gemacht. Da braucht man nicht bis in alle Ewigkeit drüber diskutieren, sondern sieht da nach Klarstellung großmütig drüber hinweg.
Gruß, silent
tommy.bb · seit
tommy.bb
Neuer Beitrag 06.10.2010 10:24
@Blue: brauchst du den Ausbau oder Einbau??
Hier Einbau:
INSTALLATION
1. See Figure 2-3. If removed, install five new screws (13)
to fasten brake discs to hub. Alternately tighten screws to
16-24 ft-lbs (22-33 Nm).
2. Place wheel into position between fork sliders with the
valve stem on the right side of the motorcycle.
3. Apply a light coat of LOCTITE ANTI-SEIZE lubricant to
axle, bearing bores and bore of spacer sleeve.
4. Slide axle through right fork slider and external spacer into
wheel hub.
NOTE
Be sure that grooves on external spacer(s), or index pin on
front wheel speed sensor (if ABS equipped), are on the outboard
side. If motorcycle is not ABS equipped, external spacers
on left and right side of wheel hub are interchangeable.
5. Push axle through front wheel speed sensor (if ABS
equipped) or second external spacer, and left fork slider.
6. Install flat washer and axle nut.
7. See Figure 2-4. If ABS equipped, rotate front wheel speed
sensor in a counter-clockwise direction until index pin
makes contact with shoulder on left fork slider.
8. Hold axle stationary, tighten axle nut to 60-65 ft-lbs (81.4-
88.1 Nm).
9. Push and hold right fork slider inboard until it contacts
external spacer and tighten axle holder nuts to 132-180
in-lbs (14.9-20.3 Nm).
NOTE
See Figure 2-3. If removed, secure wheel speed sensor cable
in bracket (cool. Be sure that tab (stamped ABS) on clip is
installed in slot of bracket from inboard side. Clip cannot be
installed once mounting fasteners are started.
10. Install left side brake caliper. See 2.15 FRONT BRAKE CALIPER
11. Depress front brake hand lever several times to set brake
pads to proper operating position within caliper.
12. If ABS equipped, install three new cable straps as follows:
a. Install cable strap on the brake hose lower crimp
capturing front wheel speed sensor cable and brake
hose.
b. Approximately midway between the upper and lower
brake hose crimps capturing front wheel speed sensor
cable, brake hose and front fender tip lamp wires, if
equipped.
c. Install cable strap 2.5 in. (63.5 mm) below the brake
hose upper crimp capturing front wheel speed sensor
equipped.
VLG
Tommy
aus Seengen
fährt: Electraglide
E-Glider ist offline E-Glider
fährt: Electraglide
Neuer Beitrag 06.10.2010 11:20
Bei meinen bisherigen Bikes war da mal höchstens 0,3 mm Spiel, wenn überhaupt.
Der Kontakt zum ext. Spacer war eigentlich konstuktiv gegeben.
Wenn da 3 mm klaffen, ist entweder ein Gabelholm verbogen, oder falsche Spacer verbaut...
Wolfgang
Ich möchte gern friedlich im Schlaf sterben wie mein Großvater!
Und nicht vor Entsetzen schreiend wie sein Beifahrer...!
fährt: FLHT
fährt: FLHT
Neuer Beitrag 06.10.2010 12:20
die achse liegt am spacer am,
der holm wird ja nur mit der schelle von unten an der Achse wo das loch drinnen ist befestigt.
da klafft immer was zwischen spacer und holm,
und das muss so sein, ansonten holme verbogen.
BLUETHUNDER
Mehlfach
BLUETHUNDER
Avatar (Profilbild) von vamos
aus Salem
vamos ist offline vamos
2492 Posts seit 22.08.2006
aus Salem
Homepage von vamos
Neuer Beitrag 06.10.2010 12:34
hat mir mal jemand Nachschub von Popcorn oder Chips ?
Meine Vorräte sind aufgebraucht.
meine HP
electronic Parts
aus Seengen
fährt: Electraglide
fährt: Electraglide
Neuer Beitrag 06.10.2010 12:53
Hier hast du beides, du Gierschlund!
Wolfgang
Dieser Beitrag wurde schon 1 mal editiert, zum letzten mal von E-Glider am 06.10.2010 12:54.
aus Salem
aus Salem
Homepage von vamos
Neuer Beitrag 06.10.2010 13:09
Wolferl, du bist so gut zu mir
Nur leider sind‘s die falschen Chips, die kann man nicht essen (weißt schon, das hat Prio bei mir).
Ich wollt schon solche mit Geschmack z.b. Paprika.
Egal - Popcorn reicht auch
meine HP
electronic Parts
Dieser Beitrag wurde schon 1 mal editiert, zum letzten mal von vamos am 06.10.2010 13:10.
fährt: FLHT
fährt: FLHT
Neuer Beitrag 06.10.2010 15:42
Damit der ‘Gierhals au net verdurstet
Alte Rauschkugel.
BLUETHUNDER
Dieser Beitrag wurde schon 1 mal editiert, zum letzten mal von BLUETHUNDER am 06.10.2010 15:43.
Karl H. ist offline Karl H. · 10210 Posts seit 05.11.2011
Neuer Beitrag 06.10.2010 16:54
Was‘n das für ein Geschrei hier!?
Da kann man ja nicht mehr in Ruhe arbeiten! 🤬
aus Salem
aus Salem
Homepage von vamos
Neuer Beitrag 06.10.2010 17:21
Du sollst auch arbeiten und dich net im Forum rumtreiben 🥷
meine HP
electronic Parts
12.10.2025 23:57
FLS/S/L Slim: Suche kleine Batterie für meine Slim (Mehrere Seiten 1 2)
von two
25
40007
09.05.2020 20:48
von two
97652
20.01.2018 11:22
von Peperoni13
