@Blue: brauchst du den Ausbau oder Einbau??
Hier Einbau:
INSTALLATION
1. See Figure 2-3. If removed, install five new screws (13)
to fasten brake discs to hub. Alternately tighten screws to
16-24 ft-lbs (22-33 Nm).
2. Place wheel into position between fork sliders with the
valve stem on the right side of the motorcycle.
3. Apply a light coat of LOCTITE ANTI-SEIZE lubricant to
axle, bearing bores and bore of spacer sleeve.
4. Slide axle through right fork slider and external spacer into
wheel hub.
NOTE
Be sure that grooves on external spacer(s), or index pin on
front wheel speed sensor (if ABS equipped), are on the outboard
side. If motorcycle is not ABS equipped, external spacers
on left and right side of wheel hub are interchangeable.
5. Push axle through front wheel speed sensor (if ABS
equipped) or second external spacer, and left fork slider.
6. Install flat washer and axle nut.
7. See Figure 2-4. If ABS equipped, rotate front wheel speed
sensor in a counter-clockwise direction until index pin
makes contact with shoulder on left fork slider.
8. Hold axle stationary, tighten axle nut to 60-65 ft-lbs (81.4-
88.1 Nm).
9. Push and hold right fork slider inboard until it contacts
external spacer and tighten axle holder nuts to 132-180
in-lbs (14.9-20.3 Nm).
NOTE
See Figure 2-3. If removed, secure wheel speed sensor cable
in bracket (
. Be sure that tab (stamped ABS) on clip is
installed in slot of bracket from inboard side. Clip cannot be
installed once mounting fasteners are started.
10. Install left side brake caliper. See 2.15 FRONT BRAKE CALIPER
11. Depress front brake hand lever several times to set brake
pads to proper operating position within caliper.
12. If ABS equipped, install three new cable straps as follows:
a. Install cable strap on the brake hose lower crimp
capturing front wheel speed sensor cable and brake
hose.
b. Approximately midway between the upper and lower
brake hose crimps capturing front wheel speed sensor
cable, brake hose and front fender tip lamp wires, if
equipped.
c. Install cable strap 2.5 in. (63.5 mm) below the brake
hose upper crimp capturing front wheel speed sensor
equipped.
VLG
Tommy
