Forum » Modelllinien » Trike (Milwaukee-Eight, Twin Cam) und Gespanne » Triglide neutralen Gang finden
Triglide neutralen Gang finden Twincam-Forum
-hohi- · seit
-hohi-
Neuer Beitrag 24.07.2012 19:07
eigentlich klappt es schon ganz gut. Ich habe aber in einem Forum in USA folgenden Beitrag gefunden:
Hello, I am new to the HD trike. I bought my blue and black trike a few weeks ago. When I was searching the web to find a trike forum, I found Trike Talk. I was glad to see a universal forum for HD and metric trikes as well. In the first thread that I saw had to do with finding neutral. When I picked up my trike, I did not notice at the time that neutral was going to be a problem. When I got home I contacted the service dept and asked why this was not addressed during prep and why was it given to me this way. They told me to ride it and break it in for the first 1K miles for service and they would make the adjustments at that time. WRONG!!! I said thank you and have a nice day so I proceeded to go to my garage and pulled down the clutch cable boot and adjusted the clutch cable so it would disengage the clutch pack fully. I know this cause I have been around HDs for about 25 to 30 yrs and know how to adjust the clutch. I lengthened the clutch cable by 6 flats. Now when I pull my clutch lever in, it fully disengages, the clutch pack goes into neutral like butter. This is the way it should be. I have now got 540 miles on the trike and everytime I come up to a stop sign or traffic light, shift into neutral, no problem.
_____________________________-
Vielleicht kann mir jemand von Euch erklären, was der Schreiber genau gemacht hat - Kupplungskabel ---------??
Vielen Dank von Günter
10217 Posts seit 05.11.2011
Neuer Beitrag 24.07.2012 21:55
Hallo Günter,
der Triker hat die Hülle des Kupplungszugs per Einstellschraube um eine Umdrehung ( 6 flats) verlängert bzw. nachgespannt. Jetzt trennt die Kupplung offenbar wieder perfekt.
Dieser Beitrag wurde schon 1 mal editiert, zum letzten mal von Karl H. am 24.07.2012 21:56.
von Floki-Midgard
15.01.2026 12:40
von Sharma
57746
30.07.2022 20:33
von MaxPower
Alle Sportster: Ruckeln im 1. Gang, welche Kupplungsscheiben? (Mehrere Seiten 1 2)
von Quadrigo
29
50697
27.07.2022 13:04
von motorcycle boy
