bevor ich hier ein Durcheinander mache, und in jedem Fred blöde Fragen stellenđ,mache ich hier einen eigenen auf.Seit Donnerstag steht meine Dicke in der Garage, gefahren bin ich bis jetzt nur 80 Kilometer.
Hier erstmal ein paar Daten, damit jeder weià was von was ich rede, und auf was sich meine AnfÀngerfragen beziehen.
 Momentaner Zustand:
 Â
Â
Â
Â
Â
Â
Â
Â
Â
Technische Daten, geklaut aus dem Internetđ
Key FLHRSEI 2 Screaminâ EagleÂź Road KingÂź characteristics
FLHRSEI 2 incorporates all the Road King FLHRI model updates for model year 2003, and includes the following additional standard features:
-Twin Cam 103âą Powertrain finished in Silver and Chrome -Black High Torque 1.4 KW Starter -High Performance Clutch with Hydraulic Actuation -High Strength Final Drive Belt -Custom Oil Cooler -Custom Oil Filter Mount with Internal Thermostat -Bright Polished Spun Aluminum Solid Wheels -Chrome Front and Rear Floating Brake Rotors -Chrome Fork Sliders and Chrome Upper Fork Covers -Chrome Lower Triple Tree Cover -Silver Brake Calipers with Billet-style Inserts -Chrome Front Axle Nut Covers -Chrome Headlamp Bezel -Bullet-style Front Turn Signals with Chrome Turn Signal
[CO... -Smoked Turn Signal Lenses with Amber Bulbs -Detachable Dark Tinted Mini Wind Deflector -Chrome, Fat 11/4-inch Diameter Handlebar with Internal Wiring -Chrome Clutch and Brake Master Cylinders and Levers, and Chrome Switch Housings Cruise Control -Clear-coated, Braided Stainless Steel Control Cables -Clear-coated, Braided Stainless Steel Front Brake and Clutch Lines -Oval Billet-style Mirrors -Silver Face
[CO... and Matching Mini Tach -Billet Mini Tach Mount with 100th Anniversary Badges -Custom Full-Length Billet Style Fuel Tank Console -Chrome Extended Reach Billet Brake Lever -Chrome Billet Heel/Toe Shift Levers -Polished Stainless Steel Shift Rod -Chrome Footboard Inserts, Shifter Pegs and Brake Pedal Pad -Chrome Passenger Footpegs with Chrome Peg Mounts -Stratum Collection Chrome Billet Timer, Derby and Air Cleaner Cover with Color-filled Script -Chrome Head Bolt Covers -Chrome Voltage Regulator -Chrome Oil Vent Line with Chrome Fittings -Chrome Oil Line Cover -Custom Leather Seat with Chrome Inserts; Fully Adjustable Rider Backrest -Detachable Passenger Backrest with Chrome Inserts -Profileâą Low Rear Suspension -Chrome Touring Mufflers with Chrome Billet End Caps -Chrome Touring Muffler Shields -Bullet-style Rear Turn Signals Mounted on a Chrome Narrow Turn Signal Bar -Custom Painted Saddlebag Filler Strips -Custom Rear Fender Cloisonne Medallion -H-D Âź Factory Security System with Alarm Siren -Saddlebag Liners -Custom Indoor Storage Cover -Custom Color -Centennial Gold with Vivid Black and Burgundy Accents -Color-Matched Centennial Gold Frame, Swingarm and Footboard Support
Â
SPECIFICATIONS:
2003 Specifications FLHRSEI2 Screaminâ EagleÂź Road KingÂź
DIMENSIONSLength 93.7 in. (2380.0 mm)Seat Height (measure laden w/ 180 lb. rider) 27.0 in. (685.8 mm)Ground Clearance (unladen) 5.0 in. (127.0 mm)Rake 26.0 degreesTrail 6.2 in. (157.5 mm)Wheelbase 63.5 in. (1612.9 mm)
[CO...: Dunlop Harley-Davidson SeriesFront - D402 MT90B16 72HRear - D402 MT90B16 74HFuel Capacity (includes approx. 1.0 gal. reserve) 5.0 gal. (18.9 L)Reserve Fuel Capacity (warning light @ approx. 1.0 gal.) 1.0 gal. (3.8 L)Oil Capacity 4.0 qts. (3.8 L)Dry Weight 745.0 lbs. (336.1 kg)Gross Vehicle Weight Rating 1058.2 lbs. (480.0 kg)
ENGINE[CO... 45Âș Screaminâ Eagle Air-cooled Twin Cam 103âąpowdercoated silver w/ chrome coversValves Pushrod-operated overhead valves; w/ hydraulicself-adjusting lifters; two valves per cylinderBore x Stroke 3.87 x 4.37 in. (95.25 x 110.8 mm)Displacement 103 cu. in. (1690 cc)Compression Ratio 9:1Fuel System Electronic sequential port fuel injection(single runner, 45mm throttle bore ESPFI)Air Cleaner/Filter Oval w/ chrome billet insert high-efficiency,pleated paper filtrationIgnition Single-fire, non-wasted, map-controlledspark ignition system; electronic breakerlessw/ multiple advance curve matrixOil Cooler Thermostatically controlled
DRIVETRAINPrimary Drive Double-row chain, oil bath, mechanical tensioner,36/25-tooth sprockets (1.44:1)Final Drive Gates carbon fiber reinforced poly chain belt,32/70-tooth sprockets (2.188:1)Clutch Hydraulically actuated 9-platew/ diaphragm spring in oil bathTransmission Five-speed, constant meshOverall Ratio:1st 10.1102nd 6.9583rd 4.9534th 3.8625th 3.150
CHASSISFrame Mild steel; square-section backbone w/ twin downtubesSwing Arm Mild steel, rectangular section w/ forged endsFront Fork 41.3 mm dia. forksRear Shocks Air-adjustableWheels Bright polished spun aluminum-solid wheels
[CO...:Caliper Type Dual-piston front and rearRotor Type (diameter x width): Chrome floating brake rotorsFront (DUAL) 11.5 in. x .20 in. (292.1 mm x 5.08 mm)Rear 11.5 in. x .23 in. (292.1 mm x 5.84 mm)Suspension travel:Front 4.6 in. (116.8 mm)Rear 3.0 in. (76.2 mm)
PERFORMANCEEngine Torque (per SAEJ607)2:North America 100.0 ft. lbs.@ 3500 rpm (138.0 NM @ 3500 rpm)Lean Angle (per SAEJ116
:Right 31.0 degreesLeft 30.0 degrees
ELECTRICBattery Sealed, maintenance-free, 12-volt,28 amp-hour, 300 cca (per Battery Council International rating)Charging: 45-amp permanent magnet alternator w/ solid-state regulator(377 watts @ 1000 rpm; 572 watts @ 3000 rpm; 585 watts peak)Starting 1.4 kw electric w/ Bendix-type engagementLights:Headlamp Quartz halogen, 55-watt low beam, 60-watt high beamTail/stop lights 8w/28wTurn signal lights (self-canceling) 28wIndicator lamps High beam, neutral, oil pressure,engine diagnostic light, turn signals, low fuel warning,and security system
STYLING/CONVENIENCEEngine Trim Silver powdercoated w/ chrome coversExhaust System Crossover duals w/ chrome touring mufflersw/ chrome billet end capsSeat Custom leather seat w/ chrome insertsand fully adjustable rider backrestPassenger Backrest Custom detachableFoot Supports Operator/passengerFairing noneFairing Air Deflectors noneLower Fairings noneWind Deflector Dark smoked Lexan; mini quick-detachableGlovebox noneInstruments Electronic speedometer w/ odometer and resettable tripmeter;fuel gauge w/ low fuel lightStereo noneAntenna noneRear Speakers noneIntercom noneCB noneHeadset none
[CO... Factory cruise w/ integrated hand controlsHandlebars Chrome, fat 1.25 in. dia. w/ internal wiringHandlebar Controls Start; engine cutoff; L/R turn signals; horn;hi/low beam; cruise on/off and set/resumeHazard Warning Integrated w/ turn signal controlsElectrical Power Outlet 4-pin accessory connector beneath seatSecurity System Factory installed w/ sirenTour-Pak Available from Genuine
[CO... Accessoriesin king or chopped configurationSaddlebags Fiberglass w/ hinged lid and chrome slant latches,volume: 1.2 cu. ft. (36L) per bagLuggage Locks Saddlebag barrel-key, common w/ ignitionFork Lock Barrel-key, common w/ ignition
