THANKS FOR CHOOSING FEULING!
Valve springs are only needed on the early T/C engines '99-'04 the late style beehive accepts the 574" cams and we have great luck with this cam as a direct bolt-in.
Decompression isn't needed
If working on the cylinder heads then yes I would recommend changing out your valve springs and doing a nice valve job. You could use either our Endurance Beehive springs #1105 or our Econo Beehive springs #1121 - both available from Drag.
you can use your stock pushrods or our adjustable #4090
Lifters - I would recommend replacing them while you are in there and using either our HP+ #4000 with your stock springs or our Econo line and our Race Series lifters with our Endurance springs as the Race Series will be quieter and a little more RPM before valve float.
Luke
On 1/24/2012 10:12 AM, Wolfgang wrote:
Dear Feuling-Team,
i´m going to the cams in my 2009 harley-davidson sofail custom
with your Reaper 574 cams. On your page you show some specifications and
recommendations for a TC96 engine. I have already installed the
Harley-Davidson big bore kit 103", currently with the SE255 cams. Out of
the 2010 drag specialities fatbook i got the information that
performance valve springs and perforamnce pushrods and lifters are
REQUIRED. On you page (and also in the 2012 drag specialities fatbook)
there is only a recommendation for that and requirement for other valve
springs. Due to that i´d like to ask you for as special recommendation
for my configuration to go ahead with the right parts.
So: My model is a FXSTC2009 with the 103" bigbore kit engine. Currently
the cylinder heads are being modified (incl higher compression rate) and
decompression valve are being installed. Big Sucker and performance
exhaust (jekill@hyde) and thundermax efi are already installed.
Which valve springs do you recommend? Do i need peerforamnce pushrods
and lifters? Are the decompression valves necessary?
Thank you very much in advance
Kind regards from Stuttgart Germany
Gruß Softail-Wolle
__________________________
