Forum » Modelllinien » Touring [Grand American Touring] (Milwaukee-Eight, Twin Cam, Evolution) » FLHX Street Glide: Mp3 brennen für original Harman Kardon Radio geht nicht
Avatar (Profilbild) von Harley Oppa
Harley Oppa ist offline Harley Oppa · 3924 Posts seit 19.12.2009
aus Gladbeck
fährt: FLHXS 107 Stage VI
aus Gladbeck
Neuer Beitrag 18.06.2013 13:18
hab das Problem das ich für meine 2011er FLHX keine Mp3 CD gebrannt bekomme die auch im originalen Harman Kardon Radio abgespielt wird.
Hab schon mal im Ami Land Forum was gelesen das die Cds nur in einer bestimmten Kodierung gebrannt werden müssen da das Radio wohl nur diese eine Kodierung kennt.
Wie brennt ihr denn die Mp3s ??
Oqpa
✠...die einen lieben mich, die anderen hasse ich...✠
Neuer Beitrag 18.06.2013 14:12
Vielleicht hilft das (im Netz gefunden)...
Zitat:
HowTo: Make an MP3 disk for the Harmon Kardon ( 12.08.2008 )
I've had some problems making an mp3 music disk that would play in the Harmon Kardon on my RG.
So I've figured out the problems and can now make the disks.
I am sure others probably have run into the same problems so I thought I'd just post a little cook book on what I discovered.
I am using windows vista so that's what these instructions are for.
Someone else might want to post the differences when using other operationg systems, like the mac, or even other windows versions, like windows 95.
Here's my cookbook...
1. The music must be in MP3 format. The HK player won't recognize WMA (windows media) format or any other.
2. You can rip the above format using the windows media player.
Just the options menu item under the "rip" tab and set it to MP3 before you start, otherwise you'll get the wrong format.
Then put in your music CD and press the "start rip" button. ( by the way, rip means - copy the music from the cd to your computer )
3. Here's the step I was doing wrong. I was using the windows explorer to burn the mp3 disk, and getting the wrong format.
You should use the windows media player. Under the "burn" tab the options menu item.
Set the playlist type to "M3U", not "WPL". Windows will default the playlist to "WPL" (windows play list), and your disk will not work in anything other than a windows player.
If you set it to "M3U" the disk will work in all industry standard players, including the Harmon Kardon on your bike. (Trust Microsoft to change the industry standard!! Typical windows crap)
4. Also under the burn tab make sure you "Data CD".
Burn the disk, when it's done it will automatically close it out, or finalize it.
Then it will work in the HK. It's really nice, it shows the artist and song name on the display when the song starts.
I really like it.
THINK BIG - ALWAYS!!
Mertes ist offline Mertes · seit
Neuer Beitrag 18.06.2013 16:23
Mit der Anleitung hab ich auch Erfolg gehabt. Und die Titel werden angezeigt.
Neuer Beitrag 18.06.2013 17:34
Dann war es bei mir Zufall. Konnte all meine gebrannten Sicherungskopien abspielen.
Avatar (Profilbild) von Black Bull
Black Bull ist offline Black Bull · 194 Posts seit 29.07.2011
aus Altenstadt (Wetterau)
fährt: 2011er Street Glide FLHX, Black Denim with J&H Big Shots
Neuer Beitrag 18.06.2013 19:08
Ich hatte bisher auch keine Probleme. War zwar wahrscheinlich einfach nur Zufall. Aber ich hab einfach über ITunes gebrannt und hatte keine Probleme.
CU
BLACK BULL
"La Pura Vida"
aus Gladbeck
aus Gladbeck
Neuer Beitrag 18.06.2013 22:20
es funktioniert genau so wie Mike geschrieben hat.
Attachment 136004
Attachment 136005
Oqpa
Neuer Beitrag 18.06.2013 22:26
Sag ich doch... großes Grinsen
aus Karlsruhe
**APE-Klaus**
8057 Posts seit 05.06.2007
aus Karlsruhe
Neuer Beitrag 18.06.2013 23:32
Stöpsel nen I-Pod in die Buchse dann hast du mehr Musik als mit den mp3 cds und die mp3 laufen nach ner Weile eh nimmer weil die Qualität zu schlecht ist und bekommen die CDs Schäden.
Weil jeder Tag zählt
Nothing else matters
Avatar (Profilbild) von Torte
Torte ist offline Torte · 250 Posts seit 19.02.2013
aus Dortmund
fährt: 09 Street Glide
aus Dortmund
Neuer Beitrag 19.06.2013 08:15
Brenn mit iTunes......das tut
Avatar (Profilbild) von Shiras
Shiras ist offline Shiras · 333 Posts seit 10.06.2013
aus Wien
fährt: CVO Ultra 2017
aus Wien
Neuer Beitrag 19.06.2013 08:20
Brenne mit NERO, keine Probleme.
Lg aus Wien
Edmund
LG aus Wien
Nobody is Perfect, but .......
loosch2 ist offline loosch2 · seit
Neuer Beitrag 19.06.2013 09:43
ich brenne mit Burn Aware. Mit der langsamsten Geschwindigkeit (1-fach).
Hab festgestellt, wenn die Brenngeschwindigkeit zu hoch ist hat der HK Leseprobleme.
(E-Glide 200cool
Gruß loosch2
Herb ist offline Herb · 13 Posts seit 14.04.2014
fährt: Street Glide
fährt: Street Glide
Neuer Beitrag 21.04.2014 15:39
Hallo.
Ich kann brenne womit ich will und egal in welcher Geschwindigkeit! Mal spielt er ein Lied dann zeigt er sie ganz kurz an und geht weiter und weiter und weiter.
Habe nun au zwei verschiedenen Mac Rechnern gebrannt, von 1fach bis 8 fach usw usw. NICHT GEHT!
Und das Update für das HK geht auch nicht zu installieren! Trotz der amerikanischen Anleitung auf deren Homepage komme ich gar nicht erst in den Setup Modus.
HAT JEMAND LÖSUNGEN ANZUBIETEN?
Das wäre echt nett und damit es einfacher ist, bitte in deutsch. DANKE!
v-rodkai ist offline v-rodkai · seit
Neuer Beitrag 21.04.2014 17:28
English / German, hey you ride an American bike fröhlich
Spaß beiseite, hatte die gleichen Probs und bin sofort auf den externen Player ungestiegen (über die Buchse mit Kabel nach hinten ins TP), habe mir aber nach kurzer Zeit das HDPDPLUS II iPod interfaceII für rund 300USD inkl. Versand besorgt, selbst eingebaut und war damit alle Sorgen mit den Plastikscheiben los.
fährt: Street Glide
fährt: Street Glide
Neuer Beitrag 22.04.2014 14:25
Hallo Kai.
Leider kostet der IPod Anschluss schlappe 490 € und diesen betrag zu investeieren nur weil das HK keine mp3 CD komplett erkennt? Dazu wäre ich nicht bereit. Und einen IPod anzuklemmen sieht nicht wirklich super aus.
Und ich denke es wird eine Lösung geben. Mit dem Windowsmedia Player geht es auch nicht.
Herb großes Grinsen
Bart ist offline Bart · seit
Neuer Beitrag 22.04.2014 19:22
Hallo.
Ich mach das mit einem fm-transmitter - 19,95€ z.B. bei Conrad.
Ladesteckdose unterm Tank, Speicherkarte oder stick rein und freie fm-frequenz im Radio suchen.
Transmitter darauf einstellen und AB GEHTS.
Das mit den "hopsenden" CDs ( egal ob selfmade oder original ) war mir auf schlechteren Landstraßen echt zu blöde.
Jetzt werden die Touren natürlich länger, damit man mal alles gehört hat.
fröhlich fröhlich großes Grinsen
Gruß, Bart
von Kallpaul2022
31.03.2026 20:00
von DeeCee
FLHT Electra Glide: Radio raus>>>Fach rein
von Allgaier
10280
27.10.2025 12:07
von Sexmachine
Biete Teile: Original CVO Felge Touring 21x3,5 Nockout
von helmutsen
28.01.2025 11:52
von helmutsen
