Lies mal die Fehler vom Tempomat aus - wie das geht steht hier irgendwo - hatte ich mal gepostet...
Gefunden:
If you were doing a throttle cable adjustment it is possible that you may need to do an initialization . Here is the scoop from the service manual:
The engine should be at normal operating temperature and throttle and idle cables should be correctly adjusted. To set the correct cable lash proceed as follows:
1. Push the Cruise Switch on the right handlebar to RESUME and hold it.
2. Turn the Cruise ON/OFF switch to ON.
3. Turn the Ignition switch to IGNITION.
4. Start the engine. The green Cruise Enabled/Engaged lamp in the speedometer will illuminate.
Wait 3 Seconds for the lamp to go off.
5. Release the Cruise Switch from the RESUME position
6. Push the Cruise switch to RESUME and hold. Cruise will pull in cable until change in RPM is detected. The number of motor steps required to rev the engine is stored in memory.
7. After engine revs and Cruise Enabled/Engaged lamp is extginguished release the Cruise Switch from the RESUME position.
8 Turn the ignition switch to off.
Some possible causes for improper operation are
If the cruise engaged lamp does not illuminate at all, check for one or more of the following conditions:
a. SET/RESUME switch faulty or not wired correctly.
b. Broken or pinched wire to SET switch or cruise module.
c. Cruise engaged lamp burned out or miswired. Lamp is turned on by module supplied ground.
d. Main 10-place connector not plugged into cruise module.
e. Faulty cruise main switch and associated wiring.
f. No module ground at Terminal E of 10-place module connector.
g. Brake light on constantly.
h. Throttle cables too tight.**
i. Bad cruise control fuse.
Default Cruise Control Diagnostics and Codes
Here is how to pull the cruise control dropout codes and what they mean. They tell you why the cruise control disengaged. The module stores the last 8 dropout codes starting with the most recent dropout.
To invoke the readout:
Engine OFF, cruise switch OFF
Push cruise set/resume switch to SET and HOLD it there while switching to IGNITION (do NOT start engine)
RELEASE the set/resume switch and watch the cruise enabled lamp....it will flash out 3 digits encoded as a series of pulses in the following pattern >>> the first digit is string of 1/4 second flashes, then a one second pause; then the second digit is string of 1/4 second flashes, then a one second pause; then the third digit is string of 1/4 second flashes and it stops.....write down the number of flashes in each of the three segments and you will get a three digit code
if you want to verify the flashes you just saw, then push the switch to RESUME and it will repeat the three digit code that you just read.....
to get the next three digit code that is stored, push the switch to SET and three more digits will be pulsed out in the same format as above.....continue advancing the codes by toggling to the SET (or verify them using RESUME)
there are 8 codes stored and once the buffer is empty, the cruise engaged lamp stays on solid.........if you want to repeat all 8 again, then toggle the switch to SET
to exit the readout mode switch the ignition to OFF
You now have 8 three-digit codes written on your arm....their meaning is:
111 No Codes, memory clear
112 Throttle roll off
113 Cruise switch turned off
122 frt or rear brake applied
211 Coast interval longer than 6 seconds (S/C button)
212 speed dropped below 30 mph while s/c button held
213 speed below 26 mph or above 90 mph
221 speed drops more than 15 mph below speed set point
222 speed decrease exceeds 20 mph per second
223 vehicle speed sensor input
231 rpm exceeds 5000
232 tach signal lost
242 high rate of engine rpm change (e.g., hit ice or slipping tire)
341 low voltage
internal failure if code 311, 312, 313, 321, 323, 331, 332, 333, 342, 343, 351, 352, 353, 361, 362, 363, 371, 423, 432, 777
